Multi- vs. Unidirectional Antenna(s) | Page 3 | SatelliteGuys.US
But I do have a ton of LED bulbs ...
Sounds like you need to get to tracking down your interference problem... Start by turning OFF all the LED bulbs, and see if that stops the interference. Then turn them on in turn while that station is tuned in, and go from there.
Maybe you'll get lucky, and it'll only be one or two flaky ones causing the issue. Hopefully it's not so intermittent that it's hard to find out which ones are doing it.
