Multiple LNBF/non-motorized | SatelliteGuys.US
pomernman
48
If I purchase the G* with the dual LNBF can another LNBF be added? I would like to get 10R without having to go motorized.
You may add as many additional fixed or motorized satellite positions as you wish to a Glorystar system. Just request a 4x1 DiSEqC switch option when ordering the system and we will make sure that it is included at no additional charge.
123W would be 24 degrees off axis for a dish aimed for the Glorystar system, so reception of this satellite would be with extremely low performance. You should consider adding a second dish or going with a toridal design dish for receiving satellites with this great of distance between.
Glorystar/Direct Sharing Coax?
delete channels fortec star mer 11
