Murphy's Law - Dish Installed with 722k and today I buy a new HDTV | Page 2 | SatelliteGuys.US
Im seriously thinking of running the HDMI cable through the same path as my cable line.
I should be ok running it outside as well correct? (It's under the eave so it should be fine) Just need a big enough drill bit to open up the hole...
The one from my 622 just went through its' 2nd Michigan winter and the one from my 722 its' 1st (but it was a rough one). Both are running outside. No problems at all. Mine are both 24awg--one is 25', the other 30'. Used a 1" bit. Hope this helps.
Ed
I might have a way of getting a 211
Question is, can I plug the cord that is now going to TV 2 into the 211 and remove the 2nd tv feed line from the 722k?
I imagine everything is all melded together somewhere because I only have one line going to the 722k vs 1 line from the satelite and 1 line from the 2nd TV.
Tech support web portal
722K intermittent IR remote failure
