Mutant HD51 4K UHD H.265 STB | SatelliteGuys.US
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Mutant HD51 4K UHD H.265 HEVC DVB Twin Tuner
Anybody tried one of these?
TECHNICAL SPECIFICATIONS:
  • CPU: BCM 7251S ARM
  • DMIPS CPU 12000
  • SoC: 28nm
  • Clocking in Mhz: 1700
  • Cores: 2
  • Max Video Resolution: 2160p (4K/UHD)
  • H.265: Yes
  • VP9 4K Youtube: Yes *
  • VP8 - Youtube: Yes
  • OpenGL ES 2.0
  • Smart Card Reader: 1
  • Common Interface: 1
  • Tuner changeable: Yes, 2 x Plug & Play tuner
  • Tuners: 1x satellite (DVB-S2)
  • Bootloader SPI Flash: 8MB
  • Nand Flash: 4096MB (4GB)
  • DDR Memory: 1 GB
  • Hard Drive: 1 x SATA interface for internal 2.5 "HDD or external (optional)
  • USB 2.0 Front: 1x
  • USB 2.0 Rear: 1x
  • USB 3.0 Rear: 1x
  • RJ-45 1000 MBPS (Gigabit) LAN port
  • HDMI Version: 2.0
  • RCA: Yes
  • S / PDIF (optical): Yes
  • Dimensions (WHD): 30 x 22 x 5
  • Display: VFD dot-matrix display
  • Supply: External 12V
  • Consumption (FSD): 13,1W | 7,1W | 0.5W
Haven't tested the Mutant brand, but have had a sample STB with the BCM7251 chipset and single tuner (plug-in).
Unit has an intuitive GUI, fast navigation, good picture quality on SD/HD and down converted UHD (my 4K died and waiting to replace), fast and accurate blind scan.
I got a sample as the sales rep indicated it would do 4:2:2.... NOT!
Engineer is working on a firmware update to address some quirks like NBC stutter, AV sync and timer errors.
If the Mutant has refined their version, it should be a nice unit!
Reactions: KE4EST and wallyhts
For that price, they should at least have a RF remote.
And the parade of receivers that sound great til you look at the details continues...
Reactions: lost_mesa
Open ATV is a great OS once you get the hang of using it. There are some odd things that feel like work-arounds in the satellite GUI. As an advanced user, even I have found myself stumped and stumbling around in the menus, especially when setting up the LNBs and DiSEqC 1.2. Probably not the best OS for a newbie, but very versatile for a hobbyist once you spend a few hours navigating and programming.
I was informed at OpenATV forum that the Tuner AVL6211 is blindscan ready. For now this function is not implemented, I wonder if it supports external tuner, some of these images support external tuner like TBS5925, I hope it does, I been looking at this receiver for a while, I purchased a K1 4K receiver and it looks good on my 4K TV i can see the channels on UHD 101 and 103.
Regards.
Tunder
If it supports external tuner does that mean it should allow for viewing of mpeg4 4:2:2? Who wants to be the guinea pig? ;)
I'm looking forward to release of the Manhattan's new box as well. Mutant box looks like a great option for those who want to run E2 but current lack of blindscan support makes it a non-option.
Only Macy's
ASC-1 and RG-11
