No not at all was not able to get thru to automated line, may be because my acct is bundled with my phone service. Tried until around 11pm. Thanks for your help.
L454 is correct for a VIP 211k, an EHD will work fine.
Thanks for the info that L454 is the latest for the 211K. To be honest I didn't know that there was a difference between the 211 & 211K. The reason for this is of course is that in the electronics industry (dvd players, TVs, etc.) the "K" normally means that the unit is "black". Since the 211K is black I made the mistake of assuming it was just a black 211.
Obviously not so and just another stupid mistake in dish's naming nomenclature.
At any rate I called last night and had it activated within 5 minutes. Pleasant surprise to be honest.
Gerry
Glad to see it's working ok.
The 211k is also smaller in size. It appears to me that while they are basically the same as far as the user goes there is some internal differences. I ordered one of the new remotes (21.0), they come with the new 722k/222K. I have read several reports that the new search button does not work on them (on older receivers), However, it does on my 211k. Does not seem to do anything different than the # button though. Also a few days ago Dish was experimenting with some new test channels that apparently messed up the 211's. Didn't seem to bother my 211k.
Chan
Alright, I had this same problem...I had CSR's try to activate my service 5 different times without it working. Try this...when you call this number, it recognizes your phone number...if that number is on your account, you get transferred to the CSR. Try calling from a number not associated with your account. When I did this(after entering some account info) I was able to use the automated service. The system activated my drive within about 30 seconds. Now here's the thing...if a CSR has supposedly already "activated" your service, then they have already charged you the 39.99 fee. If you use the automated system, you will be charged an additional 39.99 fee. Obviously if that's the case, call a rep and explain and they'll credit your account for the extra fee. Good luck and let me know how it works for you.
Before I went out tonight I set the receiver to record three programs then using the remote turned the receiver off (just like I do with my 722). Not one of the programs recorded. The test program I recorded while watching tv was still there, so unless there is a setting Im missing looks like I'll have to leave the receiver on all the time.
John
this maybe a really dumb question. but will the programs i record be in HD,or is there a difference between an SD dvr and an HD dvr.sorry if this is has been answered 100 times.
John
Limited time offer
