My another 1,8m dish is also PFA, but aluminum this time
. Got it really cheap but, as usually all metal parts were rusty and needed some radical methods to be applyed, for example- using angle-grinder to cut-off old bolts
. There was bad painting on the face of the dish, so I decided to remove all paint and repaint everything
. It took some time
Then I brought dish to paint-shop and they powder-coated and dried in big oven
. For feedarms I decided to use 3 INOX pipes and lead through them coaxial
. Polar-mount seems fine, but also needs to be painted
After I did what I just said, have put antenna and parts in the garage and looking forward to the times when I can continue this project.
