My new 76cm c band | Page 2 | SatelliteGuys.US
My new 76cm c band
Soo I get up and fixn to play...and notice no signal anywhere...not even ku..knowin my motor elevation is strippd i assume the motor dropd a hair..so i looses the bolts watch the meter in the tv and nothing..east and west nothn...hours later i find a bisket inside my lnb...yup a bisket...fit perfect...guess i should buy a cap
I've heard of bees in a lnb but never a biscuit. :confused: Glad you figured out the problem! :)
I've got a red squirrel(s) that lives in my barn and black walnut and butternut trees nearby.You should see all the nuts I find "stored" in interesting places.I keep telling them it"s a good thing they're cute,and don't cause too much mischief. :biggrin
Reactions: FTA4PA
Ya....cant be mean to lil buddy
Reactions: FTA4PA
Makeing a new lnb holder tomorrow at work..measured everything..im pretty sure it will be just right...it will fit the lnb arm and bolt holes of my winegard 76cm and hold the lnb properly..no more wood blocks and hose clamps and angle washers...i like switching out and watching ku band also..itl be simple now..
good job k.r. what kind of welding is that? TIG? How are you going to change direction of the LNB? And at which point on the surface of the dish your holder will be pointing LNB?
I have made couple of LNB holders out of 42mm INOX pipe. Such a construction allows to adjust LNB in any direction. IMG_20160310_192521 (Custom).jpg
Reactions: dsmith0429 and k.r.
It will bolt right into the origional holes for the factory lnb holder...tig welded..and no adjusting..i tested and measured my best angles and built it to just hold it there..il send pics later tonite of finished and mounted...weather permiting
Almost coffee and surfing time...cant wait..hope these pics help someone wanting to play mini c band..
Found 91w...everything i had before...found 97w. Working on tweaking it..its raining..but im on the 2nd floor padio dry..just hurting the signal..I did away with my motor..It was getn sloppy..I think i did a pretty good job on this holder
I'm glad I just saw this thread. I had tried doing C band on my 90cm with a couple of different LNBs with no luck. Hearing that you got something on a 76cm gives me hope...
Reactions: k.r.
Actuator
DVBS2 UHD chipset
