Napa aerial | SatelliteGuys.US
Napa aerial
Krapola
214
Fairfield, Cali
GOPR1318.JPGGOPR1465.JPGGOPR1597.JPGGOPR2257.JPGGOPR2265.JPGNAP Napa.jpgNAP Copy of Video Napa 4 0 05 35-23.jpg
I like where the mounted those subscription dishes. (pic 4)
Fisheye lens pictures make me feel ill though.
I was going to ask if you used a GoPro to shoot the wide angle shots. If so, was it attached to a remote-controlled drone aircraft, such as a Quadcopter?
I've been using a 3D GoPro rig to shoot onride amusement park ride videos, and these cameras work like a charm!
Cool... Those are great cameras to get shots like the ones you posted. The HD video quality is actually quite good when you consider the source (basically a pinhole camera attached to a relatively low bitrate MPEG-4 encoder)...
Which receiver to buy????
G19/97W 12053 V 22000 cutting out?
