Yes, since you mentioned its full with another sd sub coming online in January I guess that ends that...with what? KPLC?
They can't as its already pretty full with a HD and 2 SD subs.
Oh really, i was told it was going to 7.2 and the other two diginets were moving down. Well I believe you before KPLC or any other station or media group. I assume it will knock This out...right now they have two subs on. Grit is replacing either this or bounce
Ok thanks then grit moves to 7.2 and this tv is out. Well they can always watch it in good ole Lafayette if they can get This...In most raycom markets its bounce and grit. So assume in the areas where the contract with this TV is still in place once a contract is up they will replace it with grit.
is it HD on 46-1?Speaking of NBC, I get the KLAF channel good with the 8 bay.
720p HD on 46.1 and the last time I was able to get it they showed FOX 15 on it instead of NBCis it HD on 46-1?
There is some confusion as to if KLAF upgraded to HD when they took the NBC affiliation. I'm sure it is in HD but just wondered (also is it 1080i or 720p)?
Its the rca and it has the seperate vhf/uhf connector. I put the vhf and 8 bay back with the combiner and ran the combiner into the uhf connector. If it doesn't rain too much later this morning i will try the other way. Regardless i get 4 bars on WVLA and the lp 22 and 32 stations...If its the RCA one with separate VHF/UHF connections there is a switch (under one of the rubber boots) that you have to switch to "separate"
Otherwise the only connection that works is the UHF which is "combo"
that would work too but you can remove the combiner and run the 2 antennas into the booster separately (one less piece to go bad)Its the rca and it has the seperate vhf/uhf connector. I put the vhf and 8 bay back with the combiner and ran the combiner into the uhf connector. If it doesn't rain too much later this morning i will try the other way. Regardless i get 4 bars on WVLA and the lp 22 and 32 stations...
Thanks when mother nature stops I'll dothat would work too but you can remove the combiner and run the 2 antennas into the booster separately (one less piece to go bad)
like I say on the bottom of the pre-amp there is a switch that can be moved to separate
I removed the combiner and ran the antennas in their appropriate connectors...Thanks....that would work too but you can remove the combiner and run the 2 antennas into the booster separately (one less piece to go bad)
Limited time offer
