Pictures!Well sooner than I thought The parts are here today. This is more difficult than assembling that programmer LOL
Not really,no. The only display on hand is one from an ASC1. But Digi-Key is only 3 days away I'll shop this part and see what I can get for a deal.Yep looks toasted. I bet you don't have another handy either do you.
It's been awhile since I wrote the program so I had to check. The unit doesn't store the last skew when turned off because that part doesn't have non volatile memory (EEPROM).Completed
The control has some interesting properties. The skew adjust only affects the polarity you are on. When you power down the circuit the encoder resets to +45/-45 no matter the position of the knob. Recommend not using a knob that is indexed or has a pointer.
Limited time offer
