Need a 10 foot pole for Starchoice | SatelliteGuys.US
whozitsdad
19
Can someone tell me where I can find / buy a 10' pole to mount my starchoice dish.
PS...my DirectTV guy has DirectWay, DirectTV poles but not for Starchoice.
Only asking because he asked me.
Its either a 2 or 2 3/8" pipe if Im not mistaken (I don't remember when I installed mine)
Fence post would work perfect :)
If you have the current 75-cm elliptical dish provided by Star Choice, the mast size is 2-inches outside diameter. I would suggest going to a hardware superstore and investigating 2 inch outside diameter galvanized water pipe.
It can be cut to length, and will not rust.
If your dish requires a 2-3/8 inch OD mast, then fence post pipe for chain link fence systems is typically the same 2-3/8 inches OD.
Mike
