need at9 coordinates for 65552 | SatelliteGuys.US
rocky a
can someone help with coordinates for zip 65552 or tell me where to find them?
Go to:
http://emantechnology.com/lookangle.asp
Select DirecTV 1R/2/3 @ 101 and enter your zip code.
The correct elevation and azimuth will be displayed.
To determine the correct tick mark for the tilt, subtract the result from 90.
For example, if the tilt shows 26.3, it would be 90 - 26.3 = 63.7
If the tilt is negative, for example, -23.5, it would be 90 - (-23.5) = 113.5.
(The results should line up with the output from an H20, except the H20 will round the numbers).
Hope this helps...
Mpeg 4?
Big Ten Network on D*
