You CAN do this! It will be awesome when you get your first signals! A day to remember. DO NOT GIVE UP!
I need encouragement!! I just can not lock onto a friggin satellite. Not even a Dishnetwork one. If I do, I only get some of the transponders in that are supposed to be active and live. I have gone plum crazy and made sure everything is straight and on the level. I've got the dish mounted right at the bottom of the motor arm as to make sure it's the same level as the motor. I can't even lock onto SBS6 and get ONN anymore. I wish I had my camera, maybe if I took pictures you guys would see something I'm doing wrong. I'm about ready to take the dish and use it as a frisbee.
Growing up, I remember seeing the snow banks reaching the top of telephone poles and being snowed in for 1-2 weeks every year...and that was in the leatherstocking area.
I searched and found a few people mentioning missing parts, for example the LNB braces to hold the LNB arm sturdy...if you didn't get them, complain to your supplier:
http://www.satelliteguys.us/attachment.php?attachmentid=13130&d=1163656816
http://www.satelliteguys.us/free-ai...-fortec-motorized-dish-roof-3.html#post726774
That was back in the mid 1960's to 1970's, seems like it now snows, then melts, etc...back then, it just accumulated.
I think he placed the LNB upside down to avoid it hitting the roof. Since it's 180 degrees out, it shouldn't matter...just think of the insides of the (linear) LNB hortz and vertical portion as a +
Limited time offer
