need help converting a old primestar dish | SatelliteGuys.US
kooldishman
3
i need any information i can find on converting an old primestar dish to receive up to 5 different satellites i have been told it is possible to do this but can't find any directions on how it can be done any help would be great thanks.
:confused:
gotta start somewhere
You might give this thread by LinuxMan a read-through, to see if it is sorta what you are looking for.
He put 123º and 129º on a Primestar, and did a lot of thinking out loud.
Should give you some initial ideas.
This later thread is a lot cleaner, 'cause he already knew what he wanted to do, and just did it. :)
It deals with getting 87º and 97º on one dish.
Give 'em a look and if it's not quite on-target, I'm sure there are other good references.
thanks guys i really don't know that much about this stuff i am just getting started i can use all the help i can get thanks again.
welcome to the group
yeah mike has several multi lnb dishes and fred had a good threas like Anole pointed out.
there is a lot of help here if needed :)
Problem
Satmex 5 - 116.8W - Anything on it?
