need help, multiswitch not working for 3 LNB setup... Advice? | SatelliteGuys.US
darksplinky
Hello,
I now live in an apartment complex has a single dish on the building feeding the entire apartment building. It is a 3 LNB dish only, with no plans for a 5 LNB upgrade. I have two wires coming into my apartment, which I have connected to sat inputs 1 and 2 of my HR10-250 HD Tivo.
I purchased a second HR10-250 to add to my system. I put my 3x8 Trunkline JVI 35-TR38MS multiswitch inline, with my two cables going into the LNB A and B inputs, and 4 reciever outputs to the respective input on the Tivo's.
However, when running throught the guided setup and choosing 3 LNB for each Tivo it fails on the tivos, with 101 testing fine but 110 and 119 being hit or miss.
When I used this multiswitch I only needed one satellite to feed my two tivos, but now that I have the 3 LNB for 3 satellites, my multiswitch doesn't work.
I've been told I needed a cascadable multiswitch and also been told this won't work either. I've been told I need four cables coming into my apartment and also that I don't need four cables but can get away with two cables if I add a special, new splitter DirectTV installers use for the new HD channels. The installer I spoke to said it was a part number (from memory here) R34 for or R3B... Unfortunately, the company that manages this apartment complex will charge me $250 to hook up my additional receiver... If all I need is a splitter or cascadable multiswitch, I'm not going to pay that much.
Can anyone give me advice here on what I need to supply my 2 HR10-250's two inputs each that support channels on all 3 LNB's?
Do I absolutely need 4 lines from the dish into the apartment?
OR, is there truly a cascadable multiswitch and/or new splitter that will allow me to use the 2 lines coming into the apartment to supply the Sat1 and Sat2 input on each of the two HR10-250's?
Please advise on what my option(s) are and where I can purchase one of the parts if needed. Thanks!!!
David
Yes, you will need 4 cables coming into your apartment to feed your two DVR's. D* is testing a single wire multiswitch that will solve this problem, but there is no word on when it will be released for general usage.
What's happening when you plug in your 3x4 multiswitch is that it is locking the two feeds coming from the dish to the 13V and 18V no tone settings, resulting in you only being able to see the 101 sat. The 110 and 119 need to send back a 22kHz control tone to the LNB, so they need an additional 2 inputs (13V & 18V / 22kHz) as shown on a 4x8 multiswitch.
Don't dream about the SWM the HR10-250 isn't compatible with it. Be happy with 101 or get 2 more lines in the apt.
LNB powering ?
DIRECTV Raising Monthly Prices For HD
