need help wih sat dishes | Page 2 | SatelliteGuys.US
Grandude said:
Not positive, I thought that would be a better idea too, but I checked a couple of suppliers and couldn't find a legacy twin so suspect that they never made any that way. Sooooooo, if that is the case, he will need to get the duals unless he wants to switch over to Pro but then he would need to get two Pro adapters for his receivers.
Here's one source for a Legacy Twin. http://www.merchantamerica.com/utahsatellite/index.php?ba=product_enlarge&product=22635
Grandude said:
Just another thought. I don't know if the Dish500 comes with a Y adapter for two dual LNBs so you might check on this when ordering. Dishdepot list it for sale at $14.95. I just want to make sure you have everything you need when you begin your installation.
So far as I know, all Dish 500's have the Y-arm. All Dual-Dual, Twin & Quad LNB installations require it.
811 guide problem
First Look: The Best of Dish
