Need help with getting locals again | SatelliteGuys.US
voomsinthehouse
2
I added another receiver and the installer added a diplexer and another multiswitch to the line instead of just using a multiswitch that allows four receivers. I can not get locals now. Can anyone suggest a site or a model of multiswitch that of course allows the power to be provided by the receiver to power the antenna and allows four receivers.
if you have 4 receivers the installer should have put them all on one multiswitch. i have 3 receivers and one multiswitch but there is an opening for one more receiver on it.
New to Voom... need advice on what video cable to use
does stb require authorization out of the box
