need help with hr21 reciever | SatelliteGuys.US
jgkelly66
11
just switched to D* from E*.im putting a hr21 in my son's room.his tv only has component hookups for hd.his xbox 360 is hooked up there.does the reciever have component ins to run the x box through it so i can keep the hd on both of them.thanks for any help.
I'm kinda confused, is the TV in your son's room an HD set ?
If so, doesn't it have more than one component input or a HDMI ?
If it has HDMI , use that for the rec and the component for the Xbox, never mind, I see the TV doesn't have HDMI.
It looks like there is one Component output and several Composite outputs
This may be of some help:
http://www.directv.com/learn/pdf/System_Manuals/DIRECTV/HR21_web_manual.pdf
Page 6 and 7
Jimbo
Does the TV have a DVI input with 2 Audio jacks next to it, you could always use a DVI to HDMI cable... I carry them and install at no charge and most HSP tech's should as well, if not they can be had for $30-$50
need simple,easy to use remote
may 1st: RECORD HD PROGRAMS ON PC
