Need Help with my Pansat 2500A and FTA | Page 2 | SatelliteGuys.US
1. - double check that your pole is absolutely plumb. If so make absolutely sure you have your motor elevation set as-per the manual. On my motor one side has elevation and the other is maked 'lattitude'. Make sure you are on the correct scale.
2. - You can ignore that. That is for controlling a polarotor on a c-band setup. Your motor skews the whole dish as you track the arc.
3. - LNB should be straight up and down at true south (aligned with the feed arm).
4. - I'm not exactly sure what that does - I know it's called out in my CoolSat's manual. I'll look it up.
Shawn
Ok - according to my CoolSat manaul 'Network Scan'=
If you set to ON, you can find more transponders thought NIT scan
My guess is that Network scan is more like a blind scan... It's one of those things you just gotta play with I guess and see what works for you.
Ok thanks,
My motor scale is one for latitude 45 and less and the other is for 45 and more and I did that 46.1
Is it a possibility that it is the best that can get I mean due to the LNB quality
D Tube to Universal Tube Conversion
Advertise your Satellite company here!
