Need help with setting up coolsat4000 Pro with moter. | Page 2 | SatelliteGuys.US
Thanks for the link to that thread, it looks very helpful so I will try over the weekend and let you know how it turns out. Thanks again W Tracy Parnell.
The detailed step by step instruction helped greatly because I am able to pickup lot of channels from multiple satallites. Thanks again.
One other question, after I did a blind scan for Sat 97, I get lot of channels but most of them say (no audio or video signal). Does anyone know why that is? Please let me know.
Rinkushah99
Once I was able to pick up signal, I installed a second LNB which is DSS with a DIGIWAVE magic bracket and now I don't get any signal. Does anyone know why or what the settings should be on the brackets itself?
Would there be special settings for if you are using a switch? Please advise.
Rinkushah99
Yes, setup the switch with the FTA LNB on port 1 and the DSS on port 2. Then for each satellite in your receiver's setup menu you would set the LNB you are using for that sat to on and the other one off.
Example
Galaxy 10R I would set my regular FTA (linear) LNB to "on" and the DSS to off. Echostar 7 would be the oppisite-DSS would be "on" and my linear LNB "off".
I understand that but I am having problem picking up signal because the bracket sits higher then the one that came with the dish so inturn the LNB is not pointing at the dish right in order for it to pickup any signal. Is there a way or a technique that could be used to pickup up the signal again?
In order to set it up on the switch, for instance for G10 I would use port 1 as committed because the KU LNB is connected to KU LNB. And I would use port 2 for DSS LNB because thats what is connected for the Ecostar 7?
Right, port 1 to your KU LNB and Port 2 to DSS for Dish Network/Bell Express Vu channels. Then set G10 to 1 committed and 2 uncommitted and vice versa for a Dish network sat.
Satellite Active transponders
Pansat 3500 and 5000
