Need Install Help with 625 | SatelliteGuys.US
ssgstultz
Yelm, Washington
I recently purchased a 625 to run off the previous tenants dish that was already installed. THe tenant had Dish Network , but only a standard receiver.
The hook-up currently looks like there are 2 cables from the LNB one coming to receiver and other to a splitter outside. Then, there is a cable going from the receiver and into the same splitter and then into TV2. I am only able to run in single mode and not dual and have shared view enabled to watch the same channel on each TV.
I have read various scenarios for install, but would love to see some pictures if anyone has any of how to hook it correctly and get both TV's working!
Look at the lnb and see it it's a disppro or a dishpro plus and then look at the splitter and see if it's a splitter or dieplexer. A diplexer will have an in/out port on one side and a sat port and vhf/uhf port on the other. The correct hook up will be different depending on which you have.
got stuck on system info screen
Grainy/blurred HD picture - vip 211
