Need urgent help: 622, 1000+, DishPro+ 44, Can I use DP Separator w/one line? | SatelliteGuys.US
luckycat
291
Michigan
I need some urgent help... due to an upcoming roofing project I decided to move my Super Dish from the roof to a location in my backyard that will make everything much easier to access moving forward. I have a Dish 1000+ in Detroit (HD locals/etc.)
The original installation used two of the To Receiver Ports from the DPP44 switch to my 622. My question is this: Can I use a single cable from the To Receiver Ports (#1), with the power supply on that line, and just use a DP Separator near the receiver to Sat 1 / 2 in? Or are two runs required?
Thank you!
Dish Pro Plus 44
Seperator
1 RG6 Line
= YES!
Great, thank you! So I'll try using the one RG6U line from the powered #1 To Receiver Ports to the power inserter, and from the power inserter the seperator to Sat input #1 and #2.
I really appreciate the quick response, just saved me from running two RG6 lines to just one receiver.
Hey guys, just wanted to say thanks for helping out, the 1000+ is in a very nice new location, easily accessible & off the roof..with only 1 wire with the separator running to the 622.
Are These Signal Levels OK?
Newbie HD Question
