trees at a distance should be ok ... but close are a problem....
what about the height of your ant ... usually 15 to 20 ft up is good, higher the better usually...
are you sure that you are pointed good .... that ant is directional ... uhf only ...
your wiring should be good if you used it for sat... for sat you need current flow...
