Where do you buy one of these things at the best price as the link seems to be a Wholesale only link?
PSB said:
PSB said:Its a linear LNB so I would say no, but of course I get NASA here on a Linear LNB.
(Forgot it does come with a dielectric plate for Circular C-Band signals, but still do not think it will work for circular KU signals)
Methinks NOTPSB said:I will swap you one for the new Fortec
Should be around $60 SHIPPED
It does have separate outputs for C and for Ku. It also has a short jumper that allows you to combine them and use the switch feature. So, you can use it either way. You can have only one coax running to your receiver to handle both bands (great for upgrades), or you can have 2 runs with C on one and Ku on the other.
greyskies said:Hi there Pete:
Any way of finding out if this will indeed or won't work with Circular Ku-Band? If not, whether they have another version in the pipeline that will?
greyskies in sunny (soggy) South Florida
vj9999 said:Any updates on release date? I noticed one website mention June 7th.
sksatellite said:its available now, anyone carry it yet ?
crawfrdb said:Is there more than one LO on Ku with this feed? I do not buy universal feeds. If it does have two LOs at Ku, is there a C/Ku feed that sports only one Lo at Ku?
Thanks.
rayydio said:GeoSatPro makes one that is linear on the KU side. Also see DVB hardware
http://www.dvbhardware.com
Limited time offer
