Did you do the pokeyenow keyword search?
Jason,
After you do the Pokeynow keyword search, what next ?
It found nothing, as expected, is there a combination of buttons to push like there have been with some other keyword searches ?
Jimbo
Nope, just do the search, then exit. You should then get a "daily fortune" on the menu, and have an added "network services" in your network portion of the system setup.
Anyone know why when i run a network test my network services fail? Everything else passes. VOD works fine. Is it the network ports that are blocked maybe?
Check to see if UPnP is enabled on your router. Many routers are working ok (letting the ports through) yet the receiver reports the test as failed.
I wouldn't worry about it much until we actually see some live content to try it.
My router is forwarding the ports, but also indicates a failed network services test on the HR20.
Limited time offer
