New desperate satellite freak | Page 2 | SatelliteGuys.US
You'll get different opinions on this but yes.
Before you put the motor up. connect it to your receiver and send it goto zero. check to see that it does goto zero. then goto AMC6. Mark the motor dial for this position. Hang the motor plumb and level and tune AMC6 in your receiver for the best signal. lock it down the other birds should track in USALS, if not and your sure your plumb and level then switch to diseqc 1.2 commands and take the lat and lon out of the receiver.
With your short field of view be sure to set the software limits for the motor.
Negative skew
Coolsat 8100hd - EPG not working - Tried latest firmware.
