skysurfer said:I just thought of a feature I don't recall seeing here - will the MicroHD have auto-shutoff?
Yes, with On/Off and timer.
Well, I've searched every .PDF on the Pro Brand/Eagle Aspen website, and have been unable to find a spec sheet on the P870+ (the FSS stacked LNB found on Superdishes). I don't know where else to search...
Many of us are using these LNBs, and it would be great if an option for them was included on the microHD. If someone has the full specifications for this LNB, please post them here!
ynnedibanez said:10750/13850 stacked
scans 950 - 2150
cannot remember reading if this receiver does Picture In Picture (PIP)
Will the MicroHD get FreeDBS?![]()
YesBrian do you know if you can record radio channels with it?
Yes, you may manually add PIDs. Not necessary for you to manually add PIDs for Dial Global as the microHD logs all 48 audio PIDs!Also can you manually add PIDS to a channel that already will log fine. Here is what I mean (and if I remember the Micro scans more PIDS so this may be moot)
The Dial Global mux on 139W has like 35-40 audio pids. The channel logs fine on the Manhattan but only logs 20 audio pids (languages...one channel but multiple audio pids). The one I like (Classic Country) is too far down the list so the MH wont log it. I can't add it manually since the channel logs fine.
Here is a neat feature on the microHD that some of you DVR lovers should like.....
With the Time Shift feature activated you can save to a DVR recording....
What does this mean? Say you have been watching a program for an hour and you suddenly decide that it would be a great show to DVR. Press the record button and the option is provided to save the entire archived time shift to a DVR recording.....![]()
I wonder if there is any use for a Ka DTV setting on this receiver...
Limited time offer
