New GUI, Delete Recordings | SatelliteGuys.US
Jimbo
Cutting Edge
Jul 14, 2005
70,055
8,415
NW Ohio - Buckeye Country
Hey guys,
In the new gui, I have a list of maybe 15 different shows (much less than most I know)
Anyways, I typically will Record a shows entire season and delete most just before the new season starts (like now) ... this allows me to rewatch the last few episodes from the previous year as well as any others I decide I want to see again ....
I use to be able to go into the setting and you could find spot to bring up ALL the Recordings on the drive and you could check mark the ones you want ed to delete and Delete them all at once ...
Does anyone know if you can still do that and if so how, where do you have to go to do it ?
So far I do not see a way, so to delete the Series or episodes, you have to go thru each and every one and delete them individually.
C61K client connection reset?
Swm 1 install not going well
