New Hopper Model? | Page 3 | SatelliteGuys.US
New Hopper Model?
Just put the dual node outside with the dish, and you can have two Hoppers inside fed via two cables.
That would work if I only used the roof dish but quite often I have to use a ground dish because of trees and tat means I have to have the Duo is a place that I can switch between the roof dish and the ground dish.
Well I wonder how many people actually care about blue tooth in the over all DISH sub numbers? I am betting it isn't many. I doubt anyone uses that many of the new applications like "what's hot" either,but they are included with the hopper. Ota is still used widely by those who want it and as long as there are sub channels that DISH doesn't carry , they should still support ota. Having a built in tuner for ota would be nice and would make it plug and play. Now that is what you want in a flagship sat receiver. The built in sling ? Never worked as good on the 922 as the usb sling on the 722k and I don't know if built in sling would work any better on the new hopper.
That's a pretty good point but I'd like to know what the cost difference is between all of them. I can't imagine the cost to have What's Hot was very high. Now, the bluetooth may have been costly.
Just use a second node mounted to the back of the ground dish.
Bluetooth cost nothing. The hardware is already in the receiver.
The discussion centers around the cost of putting bluetooth in the receiver vs. the cost of an OTA tuner and their associated usage rates. Of course it costs to put bluetooth in the receiver. It didn't get there for free.
I don't think we will ever see a 6 tuner hopper unless Dish figures out how to make it all run on a single coax cable.
Many of us on the boards say 2 cables is not an issue, but the fact of the matter is that when the first dual tuner receivers came out and required 2 cables there was a high percentage of new connect cancellations due to customers who had pre-wired homes not wanting a second cable ran outside of their house, or where in situations where a second cable was just not possible.
They could license the SWM technology from Directv, but I don't see that happening
If my asumptions are right about the DTV SWiM system, compared to the Dish H/J, essentially the node is built into the lnb & the swim splitter acts like our tap for sharing the library. The biggest difference is that the Joeys are mostly just acting as antennas for the remotes & HD upscaling boxes (ignoring settings & such) as the joeys dont actually talk directly to the dish but rather just to the hopper.
As for a 6-tuner hopper using current tech would require a new model NODE as well. Currently the nodes convert the hopper signal into a 3+1 level freq signal (high, mid, low, return for joeys) for the hopper to convert into the 3 tuners. Current model LNBs send 2 feeds over each line so that would have to upgrade as well. But that would cause issues because then the new 3-tuner LNBs would likely not work with the older non Hopper systems (& we all now how much Dish likes using the same item for multiple system setups).
Otoh, the LNB issue could be solved via a new switch instead ala the infamous & nightmarish 3 hopper setup needing 2x switches in addition to both duo & solo nodes.
As for BT vs WiFi vs OTA built into the hoppers, I vote for WiFi & a root menu option to access it instead of buried deep inside. That or give us back the blue button linking to network, even if just done as a link from the root menu to prevent accidents. I come across more wifi connections thsn anything else sincd Dish's connection priority places it above HIC w new line but below HIC w existing line or direct hardline.
It could be years. They are going to show an updated model next month at CES in Las Vegas. That doesn't mean that it will ever hit the open market. Example, last year they showed off a keyboard remote control. We haven't seen it yet....
Have not posted recently, but with their large price increases for their "Everything Package" and also having DirecTV with another increase too, I'm back! Would like to drop one service and really need more than just 3 turners. Having both services with one DVR from both presently gives us 5 on three TV's, Home Theater, and this computer. Not really a fan of DTV, but they have some unique shows (watching prerecorded Rake now), and their new "Genie" DVR caught my eye. However as has always been the case their DVRs really suck compared to DISH. Will be looking forward to Scott's CES review on any new DISH HD DVR (Hopper) that might have additional turners. This Site has saved me from making poor purchasing mistakes for many many years. Thanks to all and HAPPY NEW YEAR!
Would 2 Hoppers work for you? That gives you 6 sat and (optionally) 2 OTA tuners. Others looking at FCC (?) filings have determined that the new Hopper will have no more tuners than the current Hopper. Built-in wifi and Sling instead. Yawn to both!
Having 2 Hoppers has it's advantages, such as having something left if one drops dead on you.
Thanks for your reply and suggestion, The Krell.
Had thought of doing that in the past with two VIP 622s, but thought it would be a "can-of-worms" having both in the Home Theater Room and setting up codes for the Harmony ONE Remote that my Wife knows how to work, changing from DISH to DirecTV DVR programing all the time. I have OTA hooked to both DVR and really pleased with what I can presently do. Wife is retiring next week so it is really a cost saving move, nothing else. Anyone else using two DISH DVRs in one room Home Theater with a Harmony (have not researched)? Can two codes even be set on remotes for Hoppers now? My present outputs from both DVRs go to a distribution powered panel in the garage that I installed when building this house new in 2001, and has worked great with 22 outlets available throughout the home.
Thanks again, maybe that would really be a more effective cost savings, if it would work! Will check this option out in more length. Open for suggestions.
I have two hoppers each with an OTA USB tunner for $30 extra. With the new big four feature that auto tunes to all four networks at once if you are watching just one I now have seven tuners in each hopper for a total of 14 tuners.
Having two hoppers also gives me a backup plan, if one hopper goes out I can still watch tv.
With the directv genie or say a new hopper with more tuners if the main box dies you could be out of tv for a week. Out here in Nebraska it takes a week to get an installer to your house and dish won't just mail you a replacement.
Thanks for your reply and yes I do understand having two DVRs is a back-up plan. I have that now having DTV and DISH. Still do not understand how I would control two Hoppers in the same room or what full integration is?
I read the FCC filing and I don't believe it discussed the number of tuners. It was rather boring to read so I could have skimmed it too quickly and missed something though.
How: Same recorded show playing on 2 TVs?
Cold Weather issue
