New HR-20-100 doesn't replay live TV | SatelliteGuys.US
spaulhus
18
It seems to do everything except the ability to pause, rewind and playback live TV??? User error or defective?
Both the -700 and -100's have this ability.
you can only go back as far as the time you tuned to that perticular channel though.
Use the top circle of buttons on the remote.
Provided you have the HR20, and not a H20 yes this should work fine.
Jimbo
It does, unless you're talking about doing it on the 2nd tuner. The HR20 only allows this on the channel you're watching.
If you're talking about the 2nd tuner, there are lots of threads on the "dual live buffers".
For some reason, it will not pause, rewind live content from the channel you are watching. It's works OK with a recording - seems bizarre and/or defective. I'm running f/w rev 0x18a - any known issues with this release?
Locals gone. Please Help?
HR20-100 vs. HR20-700
