Yes, that is true. Just ground the coax. The ground is there to dissipate static electricity build up.R-U-Q-R-U said:Also, is correct that if I do NOT have a lighting arrest system they should NOT ground the dish, just the coax?Thanks.
Sorry, you're wrong. Both the Dish AND the LNBFs MUST be grounded. They are eleectrically isolated from each other due to the plastic "Y" arm.Tony S said:Yes, that is true. Just ground the coax. The ground is there to dissipate static electricity build up.
Foxbat said:It amazes me how often a well-regulated subject like this comes up and causes no end of arguements. Every piece of consumer electronics that could be connected to an external antenna comes with a reference to the NEC Article 820-40 Guidelines for proper grounding and includes a diagram like the one I've attached, which clearly shows that the antenna needs to be grounded as well as the coaxial cable(s) from the antenna at the point where they enter the premises.
Of course, there may be local, state, or federal requirements that supercede the NEC, but your installer should be well aware of those.
SimpleSimon said:Sigh. In practice, he is right and wrong at the same time.
Regarding item #3, it's the most contentuous debate across the board. In practice, it's very rare for ground loops to be an issue, and it's usually due to some other fault in the electrical system.
ScottChez said:All done, had the installer out and two electricians out.
Recap: the dish is on the comlete other side of the house, the oposite side of the main house ground. The dish is under an eve on a lower roof, not the top roof.
They put an 8' ground rod in where the Coax enters the house (all coax is on the on the same side of the house as the dish. The Dish is also grounded using that ground wire attached to the Twin coax line.
We did not bound it to the main ground. I do not see any interferance on any tvs or hear any hums on speakers.
Am I safe to say it does not need to be bounded to the main as its so far away and the coax and tvs are also on the other oposite side of the house as the main?
jtravel said:I called Dish Tech support and told them My Dish and Coax had no ground installed by the Installer they sent in Jan.
The Tech told me that in general they should be grounded but its really only needed in some specific areas of the Country and left up to the installers discreation.
I told him the Manual says NEC code requires grounding and to please check with a supervisor if my Dish and coax need to be grounded.
He put me on Hold and came back and repeated the samething he said befor.
I asked about possible damage to the LNBF due to static and he said this is not a issue because the coax sheild is grounded thru the receiver when connected and would drain away any static.
he said he would put a note on my account that shows he and his supervisor told me I didn't need a ground.
Should I keep calling and pressing the issue or just let it go?
Funny, I do the job right because I want the customer to have a good experience. You should go find another line of work.ZandarKoad said:For me, the only reason I ground systems is:
#1 So the system works for the duration I am responsible for it
#2 So it passes Quality Control
I don't CARE about some uniform code in some book somewhere, because the QC guys don't even know about that same code. There have been times when I have been forced to UNGROUND a system to get it to work.
Limited time offer
