New Member please help. | SatelliteGuys.US
dummy3d
2
Hello to Every member of this forum,
I have a 36'' Dish with universal LNB (Chaparral) pointed at Intelsat 58W, it use to be part of the SKY Mexico Service which i cancelled a year ago.
suddenly i found this forum and i want to try FTA, I recently connected an Orasat v3 to the dish but i'm not getting any channels is this Normal?
Can I get FTA channels for this satellite?, Will the LNB work for FTA ?
Do I need to modify Some settings on the Orasat to get the channels?
Thanks in advance for your help.
And Congratulations for having a great forum.
Thank you very much for your quick help.
I will try it in a few hours when i get home.
When i do a channel search the orasat doesn't find anything, when the receiver is scanning sometimes the signal strength moves up to 99% but the quality always remain in 1.
Do i have to add the channels manually?
I am not familiar with your specific receiver, but you might have to do a smart search or blind scan to pick up the transponders (you can add them manually if you want to).
With most FTA receivers you need a quality to pick up channels, so unless you are picking a inactive transponder your dish might need to be aligned.
Good Luck!
Sharing my DVB from the UK?
central american possibilities
