new motor issue | SatelliteGuys.US
new motor issue
techno935
1,048
Pompano Beach, FL
I'm at 80.1 West longitude:
My motor refuses to go anywhere west of 129 West and no where further east of 43.1 West. Is this a limit issue? Doesn't sound like it. I thought the motor had 70 degrees of leeway. Maybe I'm wrong?
It's a Stab HH90 motor.
Welcome to the HH90 Stab motor craziness. I have HH90 myself and for the longest time I keep thinking the motor has gone crazy. Sometimes it will turn to true south when it is suppose to go to a different location....etc. I came to a conclusion that coax cable length DOES make a difference. Try reduce the length of you cable or try a shorter run into the motor and take it to the location west of 129 West, see if it works.
I am in Toronto 79.2 W, with the same dish and motor setup I am able to get 30W to 129W most likely you need to some tuning on your motor, it looks you are below the Clark belt on the east side. I had similar problem.
The motor limits are Rotation Angle ±65° that means 80-60=20°
FTA Canada
dolby digital unit ebay
