New to E* after 1.5 years with D* and have Sync problem | SatelliteGuys.US
IndianaMitch
12
Hello... this is my first post to SatGuys. I think I'm going to like it here!
Just got my first HD TV (two, actually... a Samsung HL-T5076S 50" 1080P for my family room and a Samsung LN-T4642H 46" High Definition LCD for my mother's room in our house) and was therefore ready to upgrade to HD with D*.
D* wasn't the least bit interested in matching anything that E* was offering... so I switched to E* and am very happy... except...
... the audio sync issue is driving me a little crazy.
In addition, I noticed that E* forgot to give me higher end cables when they hooked me up... so I contacted them and asked for the proper cables. They insist on sending Component, rather than HDMI.
I agreed to them sending me component cables, since I'm curioius to see if they will work as well as HDMI and if NOT using HDMI will help the sync issue. Other than the now-and-then sync issue... I'm VERY happy with my sound and picture... and blown away at the change from my little Toshiba 24" flat screen, to the new 50" Samsung. Fun... fun... fun!!
FYI... I have an inexpensive Onkyo receiver (home theater with 5.1) with only ONE digitial optical audio input, so I'm running an optical switch so I can use my HD DVD and my vip722 DVR, without yanking audio cables in and out of my equipment.
I have MUCH to learn... so please feel free to teach me. I can tell this forum has some amazing knowledge in the treasury.
Merry Christmas!
mitch
Firstly :welcome to Satguys
Couple of quick questions, do you just have a 722 or a 722 and something else for your mothers room ? do you have the issue in both rooms ?
If you have 2 receivers do you have the lipsync on both receivers ?
on the 722 What do you have set for option 6, 1 , 7 (tv1 audio sync) is it sync for HD ?
Many have reported lip sync but on some channels and not others, i did have it a lot originally but either dont have it or dont notice it. anymore
There have been a lot of reports of lip sync issues. I get them as well, although not too frequently. I often notice it when I first tune to a channel, but it seems to go away after 20-30 seconds. Sometimes though, it won't go away.
I did some research when I was thinking of going with D*, but I've noticed a lot of the same complaints over in that side of the forums as well.
I can say though, I never had any lip sync issues with cable.
I e-mailed E* a few weeks ago about the issue and got a fairly lengthy response saying they are aware of the issue. They narrowed it down to a combination of software bugs and problems with the feed the receive from the channels themselves.
Which transponder to use when pointing dish
VIP722 Controlling 3 TV's
