So I'll probably call tomorrow to place my order. Since I'd like to support this excellent forum, I'll probably call the DishStore guys (unless someone can give me a good reason to order through someone else). As best I can tell, price, hardware, extra goodies, etc. will all be the same regardless of who I order through (right?), except through these guys I'll get an extra rebate (in my case, a VISA gift card for $125, since I'm going to order the Top 200 package) - and help support the forum - a nice win-win.
Running through my hardware setup one last time, here's what I think I'm looking at:
TV#1 (downstairs, family room): This is a new HD TV. I want the DVR on this.
TV#2 (upstairs, bedroom): This is an SD TV, and probably will not be upgraded anytime soon (the wife says one new TV is plenty). We do not want/need the ability to record here, but do want to be able to play back content recorded on TV#1 downstairs.
TV#3 (upstairs, office): This is a small, SD TV. It will not be upgraded. I do not want/need to record or play recordings here. It just needs a signal.
Plugging these options in to Dish's website, it appears to want to give me:
Right now we have coax cables coming in from 3 different points in the house's exterior walls: the two upstairs TVs have pretty simple cables that come in through holes near the TVs. The downstairs TV is fed via coax cable that comes up through a hole in the living room floor. That's fine. That cable is run in from the outside of the house into the basement (unfinished, some of which has easy access but some of which is an uncomfortable crawl squeeze through a crawl space), then it comes up through a small hole in the living room floor (behind our entertainment center).
Currently there is no cable running from the room that has TV#1 in it to the room with TV#2 in it, and I'm not looking to drill any more holes in the house. I'm certainly not looking to have visible cables running around.
I'm assuming that there will need to be a cable running from TV#1 up to TV#2 - at least if I want to be able to watch recordings from the DVR on the TV upstairs. How is that going to work? Will there essentially be two cables running into TV#1 - one that brings the signal in from outside (following the old coax routing?), and a second cable coming out of TV#1, going back outside the house, then routed up the exterior and then back in the house to feed TV#2? How big (fat) are these cables? I haven't been bothered by single feeds of coax, but would rather avoid doubling the size of the cable holes in walls. How good are these guys about sealing the holes?
Sorry if I seem to be obsessing over details, but I don't want there to be any surprises, any excessive/unsightly cabling, or damage to the house. I do want as simple, clean an installation as possible.
Many thanks again for the help - this is a great resource.
- One 622/722 HD Duo (2TV) DVR (I assume this gets attached to TV#1, with an extra feed to TV#2)
- One 301/311/311k/381 SD Solo (I assume this gets attached to TV#3)
