F flix2 New Member Original poster Feb 22, 2005 2 0 Feb 24, 2005 #1 VOOM newbie; Dish 6000 w/locals oldie. VOOM OTA uhf reception fine, but no signal from one local vhf channel. Installer said to buy and install inexpensive YAGI. Will VOOM do this? Papatom
Shawn95GT Tivo fanatic Supporting Founder Feb 9, 2005 2,278 1 Phoenix, AZ Feb 24, 2005 #2 As far as I know, the Voom reciever will only do HD channels. Is it a HD channel on VHF? I doubt it. Shawn
R rvsixer SatelliteGuys Pro Jan 9, 2005 203 0 Feb 24, 2005 #3 As far as I know, the Voom reciever will only do HD channels. Click to expand... VOOM OTA tuner receives ATSC DTV (in either SD or HD format). DTV can be broadcast on either VHF or UHF. Rob.
Shawn95GT Tivo fanatic Supporting Founder Feb 9, 2005 2,278 1 Phoenix, AZ Feb 24, 2005 #4 You are correct - bad choice of words on my part. I need to train myself that ATSC / DTV does not equal HD. Shawn
mdonnelly Supporting Founder Supporting Founder Aug 26, 2004 8,183 2,979 Mustang, OK Feb 24, 2005 #5 Shawn95GT said: You are correct - bad choice of words on my part. I need to train myself that ATSC / DTV does not equal HD. Shawn Click to expand... HD must be digital. Digital can be either VHF or UHF. Therefore, HD can be VHF or UHF.
