No reboot ? | SatelliteGuys.US
No reboot ?
beer4me
160
12
Gowganda North Ontario
I did the firmware update last night [ 08/29 ] via sat. All went well until the reboot . The screen went black , the light remained green , and the remote had no effect. After waiting about 30 min. I gave up , and , unplugged the power. I powered up this morning , and , all seemed fine and normal , and the info showed 08/29 . I don't see any apparent issues . Anything I should know ?
the last couple times there was an upgrade that happened...I mentioned it in the last 2 upgrades
Per the notes on the 8/29 software
Changed: After future .abs updates, the unit will automatically re-boot without user needing to power cycle.
so starting with the next upgrade you wont need to power cycle (unplug from outlet)
slaving the MicroHD
