no signal strength | SatelliteGuys.US
no signal strength
pippin25
12
I get a good clear picture on the 137 degree west satellite through my 4dtv c-band only receiver, but on my fta receiver I can't get any signal strength on the quality bar. The fta receiver is set up as follows: LNB type: STANDARD LNB LOC. Freg: 5150 Polarity: Horizontal Downlink Frequency: 3880 MHz Symbol Rate: 25.190 What else can I do to get these channels?
The 4dtv reciever I believe picks up digicypher and dvb signals, the dvb reciever does not pick up digicypher signals. Could be the freq/sat your on may be a digicypher feed. Other than that, the only thing I can think of is your freq setting for your lnb. Is it a linear, circular or universal lnb? Linear freq is 10750, universal is 10600 and circular is 11250. try these and see if it works.
I have done power scan.factory reset.plug/unplug.and everything you suggested over and over again and still nothing.Any more suggestions will be greatly appreciated.Thanks for all your help.
IA8 signal?
2 Types Of Dishes At Once???
