No sound... | SatelliteGuys.US
No sound...
brawnz
2
I just downloaded the Recast online and when I first used it I was able to get sound and was able to rip off the stream. Since then I restarted my computer and now the application says "Connecting to media" then "Ready" then back to the prior message. I did not touch the settings, I also tried the beta and still will not work. Any suggestions?
What type of internet connection do you have?
It sounds like it is buffering and can't get a good stream.
Are you trying to surf/download on the computer at the same time? Do you have other computers on your network using up the bandwidth?
D.
I have DSL, there are no other pcs. I am not downloading anything else. When I access xmradio online. It also takes 30-60 seconds to buffer. But with the Recast Online its is not connecting at all. Im on a LAN not wifi either.
WMA support
