Well, just checked the sig meter and it's back up around 10% again.
Fluctuating around 5%.
Hmmm INTERESTING.
Tim
Hmmm INTERESTING.
Tim
From a recent issue with very wet snow building up on the antenna here it seems to be 6 dB above the noise and no lock can be obtained."I would like to know what Signal to Noise ratio is expected to provide adequate signal level to produce an output from a DVB-S input signal."
"The other day I on a lark, I lowered my tower and found that the very top of the mast was causing some signal disruption for my Noaaport downlink. Since I nested the tower the signal has been great. "
GOES 12 GVAR user said:I understand now.
Ya, having anything in the L.O.S. of the satellite could cause issues.
I am one who perfers on a clear shot. Though I understand that for some that is not possible.
When you refer to nesting, I assume it has something to do with securing/grounding the tower.
It seems like when the weather gets messy that is when a problem creeps up.
Tim KC0HWG
OK,"Can I use my PCI DVB card to receive weather data? If so, how"
Tune your DBS receiver to 3956 Mhz
Limited time offer
