Non-linear Stretch Option For 4x3 material? | SatelliteGuys.US
GreatMac
SatelliteGuys Guru
124
I am fairly sure there is no such option, but it seems like a grave omission: Many Voom customers have HD displays (which are 16x9), but still watch some SD programming, which is 4x3. The two options I see available either create short fat people (when image is stretched), or crop the top and bottom of the image. Most HD monitors cannot do non-linear stretch when fed through HD input.
Non-linear stretch would go a long way to make watching 4x3 material more enjoyable. It should be a fairly easy option to add.
Yes agree the VOOM stretch sucks. However, I just got finished with 3 months of HD monitor research...and can't recall one set that was not capable of doing 4:3 stretches over the HD inputs (I was looking at Hitachi/Sony/Toshiba CRT RPTV and Sony/Panasonic LCD RPTV).
Rob.
Don't know RPTVs. Virtually none of the plasmas do it on their HD/computer inputs (I have a Panasonic), and the same goes for most LCDs that I have seen (I have Syntax 30"). Some may do it if fed 480, but not with anything higher.
Okay interesting...did not know about plasma/direct view LCD. I believe all formats above 480 are only 16:9 anyway though (480i=4:3, 480p=4:3/16:9, 720p=16:9, 1080i/p=16:9)?
rvsixer said:
... I believe all formats above 480 are only 16:9 anyway though (480i=4:3, 480p=4:3/16:9, 720p=16:9, 1080i/p=16:9)?
You are right about the formats. I guess it gets up-converted depending on the input and this is why it doesn't allow the non-linear stretch option (e.g. S-Video in allows non-linear stretch, but component or VGA in do not.)
Wish Voom would get a programmer to spend a day on this.
Ota Snr#
How do I use "Program Planner"
