Non-Responsive Remote Control | SatelliteGuys.US
jgantert
1,903
Aberdeen, MD
Has anyone noticed that with the new software, when you are going thru the favorites menu, that the remote control will become non-responsive?
I'm using the original Voom remote as well as a universal remote, and both experience the same behavior. Simular to having near-dead batteries in the remote control.
However, when just watching TV, I can change channels by ch+/- or typing in the channel numbers, and I can navigate the surf bar without any problem.
Any thoughts?
Thanks,
-John
OK, I'll call Voom and see what they say...
UPDATE: CSR has never heard of that problem, so I have a service call Monday. They're going to swap the box, and if that doesn't work, the remote. However, I have a universal remote with the same behavior, so I don't think its the remote. Maybe the remote reciever on the box is going bad???
-John
I just experienced similar problem. I was not trying to access Favorite channels though. I was in the middle of watching a movie and all of sudden the receiver no longer responds to remote control.
I don't think the problem is remote control. The receiver itself seems to be 'locked'. I tried to switch the receiver to Stand By without using the remote and the receiver would not respond either. The Stand By button still works though because if I hold it down, eventually the receiver was reset and remote control works again.
Seems like a bug :confused:
Ok, found the problem. I have an RCA remote extender, and for some reason the unit was interfering with the Voom remote. I remove the transmitting part of the extender to a different part of the room, and it works fine now. Go figure.
I still have the service call tomorrow. They need to repeak my dish (was at 96, but after last weeks wind storm, I'm down to 85).
-John
Vertical colored line on SD channels
Bug in version 7.2x, (anyone else?)
