Now a member of the 4' c band club | Page 2 | SatelliteGuys.US
dem0nlord said:
Andrew does make a polar mount for the 1.2M. I purchased one from Dow Electronics.
I have this dish is the mount that is standard is that a polar mount? It attach to a 3" o.d. pole and has the scale on it to elevate from 15 degrees to 90 I think. Id this is so then what motor would work with it?
Sure, you can motorize it by putting it on the polar mount. This would then use a linear actuator to move it. Use a 36V actuator, or there are DiSEqC actuators available. Just keep in mind that like the DiSEqC motors, a DiSEqC actuator is going to be slow moving.
I'd strongly urge you to go the 36V route though. I can't imagine anyone doing C band without an analog receiver, they cost next to nothing, and will drive the 36V actuator.
Back for a moment or so to the subject at hand. Say I wanna get a 1.2 M dish with HH120 motor (heavy duty), plus a C-band LNB. How well would the signals come in?
Dr. Hydro....what have your results been so far as of today. (9/14)
I'm seriously considering this cost effective method of getting C-band.
Hi Techno,
I only played with that for one afternoon, now I have a ku LNB hooked back up to the dish. One of these days I will play with the c band on the 4' some more, but first i want to get the proper scaler ring as i am fairly sure I was picking up interference from my c band dish.
Keep playin.
and posting your results. Someday, I may talk the wife in to letting me put out the P* as it's now in the basment collecting dust. Would be interesting if someone posted a list of what exactly you can pick up on which bird using a p* and C band lnb. I'm guessing you could strap a cband and invacom quad together for both c and ku? Would be nice if someone made an lnb that did both ku linear and circular and c band too.
Strapping a Invacom to a cband might be more difficult. One, its heavy and two, have to worry about linear and circular KU offset.
I think that a c/ku lnb with a offset circular (DBS) lnb would be better. THe circular KU signals are much stronger and don't need to worry about lnb skew.
NIT question
Diseqc confusing the motor
