Does anyone know where I can get an adapter that allows me to plug my null modem cable into a USB port? I would liike touse my lapop with my Fortec, and all I hae is USB. THANKS in addvance!
I've loaded firmware into my Satpros.I can use my laptop and not have to unhook anything.
And I can use it on my SatPros also.
It will be nice to do channel editing now.
yeah ask them first if it will work or if it needs an adaptor
didn't know if the cable listed is a null or straight
but if its straight then you can get an adapter to convert it to null from rat shack
Used an old spare laptop boat anchor (P1-233mhz), just because it has a real serial port.
Later, I might go for an upgrade to a smokin' P2-266.![]()
Once you've done some channel editing, you might want to throw a post about it to the Satpros Self-Help thread.
Might encourage others (maybe even kick-start me)![]()
Limited time offer
