Weren't we expecting the DishOnline features to be included in this release.
Nope, we knew it wasn't going to be in this one. I think someone mentioned Summer? or was it Fall?
I got the corrupted hard drive message this morning, too. Pressed OK & it rebooted, all recordings intact, but still 3.66.
Can anybody answer this question? Was it explain already?
Can any of you guys explain to me why E* is duplicating all the HD channels (except the Voom channels) in the ALL HD channel lineup? Now there are duplicates of HBO, Shotime, Starz. Also Discovery, National Geography, Food, etc. Why they need to do this? Its confusing to me. Can it be change?
Scott just made many members crap their pants
Hi Guys.
I just had my first crash with L4.01.
I was in the main Dish On Demand Screen (I hit the DVR button on my remote)
I noticed that Option 3 – TV Entertainment was not grayed out like it normally is where there is no VOD programming to watch, so I selected it.
There were no programs (I got the Please Check Back Later screen)
I clicked DONE and was back at the Dish on Demand Screen
Now I selected option 2 for movies and more.
The screen went black and a few seconds later I saw a searching for signal screen, it checked different transponders and different satellites looking for a signal (I have 61.5, 110 and 119 using a DPP 44 switch with a DPP Separator to my 622)
After that I got an 002 screen, but the odd part of this screen was that the Channel, satellite and transponder information were BLANK (see the attached bug.jpg.)
Now trying to watch TV and I was getting a check switch error screen. However if I go back into the guide and select another channel I do get a picture. Once this happens all is well again and I can watch TV from any satellite or transponder.
After this happening a few times I did go and did a check switch and now satellite 110 is missing, saying NC. Before doing the check switch I had 110 and in checking the strength on a few 110 transponders signals were in the high 80's (119 were all around 120) looks like my dish needs a slight tweak to 110) (see bug2.jpg attached) If I go into system info, I do see GREEN where the 110 connection should be. (see bug3.jpg attached)
Why is it green where 110 should be when it's not there? I also noticed without 110 (after running) check switch the customer service application is grayed out and I no longer have the Dish On Demand screen when hitting the DVR button instead I am taken directly into my DVR recordings.
When I get home tonight I will head out with my Birddog meter and test the dish and LNB and peak as necessary. I will also power cycle the receiver. I am logged into my 625 receiver with my slingbox and
I am reporting this as it seems to be a L4.01 issue, as I had no problems with the L3.65 software. I am told by my wife that 110 is working on the 625. (I am trying to get her to hook it up to the slingbox so I can see it and control it from work)
I should note that no other SatelliteGuys member is reporting this issue, so it could be something hardware related on my side. I wanted to report it, just in case.
Limited time offer
