Is anybody familiar with the "ERD" setting that allows recording straight to external HDD?
Dish sure has a way of doing things in a very unbalanced way.
For one, my external HD works about 80% of the time on transfers.
However, from time to time they fail with about a minute to go. Other times they fail after the transfer, thus removing the file from both the internal and external HD. That is VERY frustrating.
And Sometimes, it screws up bad enough that the External HD keeps running the process, thus not allowing any more transfers, and giving the "an error occurred while transferring file" message on any further attempt to transfer ANY other files.
In that instance I have to have enough patience to just "back away" for a while, and hope I can get it to work later.
Anybody else have these same problems???
I'm hoping I'm not the only one.
My External is a WD 500GB My Book Essential Edition External HD. Brand new.
I'm excited. After leaving dish because of the 921 I am back as they have it on the ball at last.
My question, can you record to a HD attached to unit 1 and then take that HD to unit 2 and play the content back on unit 2 you recorded on unit 1?
You can only move to different STBs three times right now. This seems to be to allow you to save recordings and restore them onto a replacement ViP unit, should one start to fail. Later, they will allow unlimited on the account. Not to take to watch on a neighbor's TV.
Also can you select where the recording goes (internal HD or external HD)?
Not yet, maybe later. Right now, you record onto the built in HDD. You can then move it to the external. Then you can play it from the external, or move it back to the internal.
Will any of the non-DVR units (211) except the USB HD and play back the content or is this planned?
We should see this later. Perhaps as early as December. Perhaps not that early.
I have the same external drive you have on one of my 622's. So far...knock on wood...I have had no problems transfering anything. I have transferred a number of recordings at the same time..about 5 hours of transfer time.. and no problems, it was a mix of HD and SD. I have already filled my external drive with recordings so I am going to buy a few more My Books and have a theme for each one. Maybe Movies, Sports and TV shows to start with. I have many other external drives, a few Lacie, Buffalo (which is great becaus I use it for my home network and backup all the kids documents and music and I am the process of buying more drives to backup what is on there..just in case) of course the My Book. I have a mix of network storage and just the USB external storage units.
Will this be available later for DVR 625 or PVR 721 or are they going to offer and exchange/upgrade to a different receiver
It sure would be nice. But that's not what we've heard. Maybe Scott can clarify.
Meanwhile, I wouldn't be the first to try more than 3 moves.
What's the quickest way to get to the USB recordings using the remote? To get to the recordings list, you just press DVR - DVR on the remote but how about to the USB recordings. Do I need to press DVR - 4 - 1 - select - move over the menu and press Play? This is for my daughter that is now having some trouble accessing the recordings on the USB drive.
Thanks.
4 dvrs and the number 4
Limited time offer
