And no doubt, if one of us dropped $22K on one of those, in our next breath we would complain about the $40 activation fee.
A few people who got L4.41 and hooked up drives (including Smith, P) have been prompted to format their drives. Afterwards. they get the prompt to call and active the External support if they try to access the USB 2.0.
So my question is, when the HDD support officially roles out, is going to reformat my HDD?
Folks I think we are freaking out for NO good reason; has anyone actually seen the prompt to reformat on any drive?
I am confident that after you activate it, THEN it will ask you to reformat.
Not losing any sleep over this one.![]()
Also, Scott, they mentioned a special 800 number to call and register this HDD. I'm sure you will be posting that tomorrow. (Just a reminder)
When you connect it to your PC, does it appear as (1) or (2) drives ?? I would think that the enclosure's controller card would make it transparent to the OS as to how many physical drives are inside.I got my answer on my WD 1 Tb drive. It is actuially 2 500G drives in one case and they said it would likely not work.
Doesn't everyone who has L4.41 know the number from either the screensaver or the prompt they get when connecting an external drive ?Also, Scott, they mentioned a special 800 number to call and register this HDD. I'm sure you will be posting that tomorrow. (Just a reminder)
When you connect it to your PC, does it appear as (1) or (2) drives ?? I would think that the enclosure's controller card would make it transparent to the OS as to how many physical drives are inside. Doesn't everyone who has L4.41 know the number from either the screensaver or the prompt they get when connecting an external drive ?
I asked the question not to freak out, but to determine if I would need to back-up the MyBook before I plugged it into the 622. I'm not going to use the mybook as a permanent drive attached to the 622. I just need it for a short time to transfer all my stuff from a dying 622 to a new one. if it reformats, so be it. But I need to save the files that are on the mybook before I do. After I transfer the stuff, I'll re-re-format the mybook back to windows for use on my pc.
what I'm seeing (by reading all the posts) is that it's the upgrade to L4.41 that prompts the format, not the activation. That makes a lot of sense for people who don't yet have it not being asked to format the drive when they plug it in.
So here's another question, when (time) does the software normally roll out? Overnight? The deal is, I have a brand new 622 sitting ready to go but I've been waiting for Wed to pull my stuff off it. Obviously the new 622 doesn't have the new software. So will I have to wait until Thurs to put the files on the new one (overnight for upgrade) or will the upgrade happen when I first plug the new 622 in and it initializes for the first time?
I got my answer on my WD 1 Tb drive. It is actuially 2 500G drives in one case and they said it would likely not work. no problem!@ It goes back to work in my business and I'll just buy the lowest cost per G drive for now. Likely a 500G drive.
When you go to multi media and hit usb storage the number come upto activate it at 1- 888-241-2205.
I am almost thinking of plugging it into my PC and formatting it for use ont he PC then plugging it again into the 622 (and hopefully it formats it) I didn't do anything with it so far except take it out of the box and plug it in to the 622, where it recognized the drive but it did not format it.
I was surprised how fast the reformat was. Is that a Linux thing?
Everyone should have L441 by tommorow.(At least that is what I was just told)
Unfortunately the person I spoke with did not have any idea if my external drive will work with my 622.
Limited time offer
