That does not help, the recordings still show as watched.Turn off prepare for mobile.
Yes, you can, it just takes a little longer for the transfer to your Tablet/Phone. If you don't really need a program directly on your mobile device there is no effect at all.I only had the original Hopper (no sling) before, can we still use Dish Anwhere if prepare for mobile is turned off?
I am only talking about recording made after it was set to off as that is all that are left unwatched and not deleted. I delete immediately after watching.It won't fix any recordings retroactively, just future recordings.
Then you are not set to off. Since I set mine to off, and it is off, I no longer have the issue on any recording. Have you done a mobile transfer since setting it to off? Did you get a popup asking you, on your mobile device, if you want to "To make all of your recordings available for transfer to your mobile device, Select OK?" If you selected OK you reset it in your Hopper to ON again. If you select Cancel on that popup the transfer will still happen on that program but leave the H3 set to Off.I am only talking about recording made after it was set to off as that is all that are left unwatched and not deleted. I delete immediately after watching.
Then I don't know what to tell you. You must be an enigma because turning it off works for virtually everyone else....
YesI only had the original Hopper (no sling) before, can we still use Dish Anwhere if prepare for mobile is turned off?
the 4k Joey is on my 4k TVJust a question why pay for the 4k Joey and put the 4k Hopper 3 on a none 4k TV instead of putting the Hopper 3 on your main TV?
Dish has had this function for years by using the pip software. You could simply freeze the program you were watching, press the swap button without opening a PIP screen, and freeze and swap between 2 the tuners at will - my prefered way to watch 2 programs at once in lieu of the annoying (but still greatly appreciated) PIP video window - especially useful at half times. Now, on the H3, the PIP button operates the same way.Thanks! Couldn't find the swap button on my remote (52.0) so I got the manual out and discovered it's the input button on the side (guess it pays to read the instructions after all!). I'll give it a try...
I had seen the free year of netflix advertised online and just asked about it when I called. The rep said it was an active offer until the end of February so there's still time. Same with the free gift card!So how did you do it?
It can take up to 24 hours to download the guide and VOD.I understand not having icons for awhile is a waiting game. Dish considers not having over half of your tuners available a hardware issue. Waiting wont fix a hardware issue.
- I still haven't figured out how to do a seek style timer. Not sure if that's the right description, but I used to have (GB Packers fan) timers set up for football; "at Packers", "Packers at", "at Green Bay", and "Green Bay at" to capture all the games without all the random fluff.
"Dish Pass" feature from VIP receivers or "seek and record" from early Hopper is missing. This is a critical feature to allow timers to be created with just a keyword.
Have either of you figured out hot to "Seek & Record" That was a great feature & I hope a software update fixes that soon!
We want to hear how about your ordering experience!
I did the ordering. I had 10 months left on my contract & had to extend it for 2 years. The rep wanted me to pay $8 per month for a service contract. He could explain why I would need that & could answer what the standard warranty period was. He seemed frustrated so I ended the call & tried later. The next person said they would cover the 1st 30 days. They also wanted an installation fee. When I balked at that they say OK, free.
We want to hear about your install how did it go?
Tech was a little late but no biggie.
We want to hear what the Techs did and upgraded at your house!
The tech needed to install a different LNB which didn't take long. It did take a while to download things before it fired up. He was at my home for about an hour to 1.5 hours.
We want to hear your thoughts on the Hopper 3!
My first impression was the picture looked darker. It took my hours to figure out how to do Picture n Picture. When I finally figured it out the receiver went haywire after about 20 minutes. It looked like several pictures were present & had lots of vertical & diagonal lines. I had to push the red rest button to fix it & no problems since.
I cannot figure out how to "Seek & Record" no could a Dish rep who in fact had no idea what I was talking about.
We want to hear what you would change about the Hopper 3?
The bottom is I don't like the remote so far. The old remote was big but overall much easier to fine things. With the new one you must dig through several buttons to do simple things. I get used to it but doubt if I'll ever really like it.
Limited time offer
