ok, somebody draw me a map | SatelliteGuys.US
shultz
217
2
87W 40N
damn manuals! how do you setup the "c" side on a coolsat6000? if i go into the install and turn on the switch, it gives me the option for imput 1 commited, and 2 for uncommited, and i can't add the feq 11250 anywhere! the only place that has 11250 i've seen is on all the echostar sats, and it came from the factory like that. all the other sats are setup for single, 10750. i've got a cable from the "c" side and a cable from the "l" side going into the 4x1 switch, out of the switch into the motor, out of the motor into the receiver. i've been able to pickup at least something on all sats i've aimed at, but how can you tell if its "c" or "l"??
the only satellites that use Circular are
Echo 3 (61.5)
Nimiq 2 (82)
Nimiq1 (91)
Echo 6,8 (110)
Echo 7 (119)
Echo 5 (129)
Echo 1,2 (148)
those you set fir single with frequency of 11250
leave the 22khz and the diseqc switch set to off, and just use usals? then change the feq on those sats ONLY? i might be able to do that....Thanks again!
Picture quality -- rant.
Preparing FTA order - do I have everything?
