Cell phone's will have fallback to 4G and 3G for a while which mainly makes it a issue with single band fixed home service...
If most of their frequency is above 6 Ghz then why are the trying to get 100 Mhz of the lower C Band range?
Rain fade will have near zero affect on 5g service. You have made assumptions about rain fade that are false. I work in the satellite business, we use frequencies all the way up to 30 Ghz. At C band, 6 Ghz uplink 4 Ghz downlink rain fade is not a factor. Maybe 1-2 db fade at most. Even at 30 Ghz in a downpour, less than 4 db usually. A short terrestrial path such as cell sites you will see no issues.
I have worked in the satellite industry both military and commercial since 1982. Some of what you are saying sounds like what a sales person or manager would say, not an engineer or technician that works in the field.Rain fade will have near zero affect on 5g service. You have made assumptions about rain fade that are false. I work in the satellite business, we use frequencies all the way up to 30 Ghz. At C band, 6 Ghz uplink 4 Ghz downlink rain fade is not a factor. Maybe 1-2 db fade at most. Even at 30 Ghz in a downpour, less than 4 db usually. A short terrestrial path such as cell sites you will see no issues.
I thought I heard a while back that the future was people's ota antennas would not only receive but transmit signal (mesh) to get other people signals that couldn't reach the towers directly. I'm surprised that this isn't implemented into more devices for a company to use to have service available in many more locations.
Sent from my iPhone using SatelliteGuy
From everything I have read that isn't quite true or maybe a better way to put it, there is more to the story. 5G is most certainly subject to rain fade.You are correct distance to the cell site when short will minimize it. But in heavy downpours when it becomes more dense those at the outer limits of signal indeed could see a significant fall off. That doesn't mean it can't be overcome of course by making sure there are enough towers and maybe stronger receiving antennas where needed.
Put rain fade together with the signal does not penetrate buildings as well and there is the chance for situations of losing the signal or it being too low. Again, no doubt it will be overcome by finding ways to mitigate it.[/Q
That may have been someone's fantasy, but I suspect that it has little to no basis in reality. I reason that OTA reception antennas make for lousy transmission antennas. Further, any of them that has a conventional amp or pre-amp on them literally can't carry a signal backwards to the input side of the amp.
Yes! I was so sad when apple took away the ability to see the numerical signal strength. I used to find the best signal in my hotel rooms and such to run the hotspot from.Yup, I've got a smartphone setup as a hot spot and fastened to my bedroom window with velcro because that's where it picks up the best signal from the cell tower it's connecting to.![]()
Limited time offer
